Using Apollo to Create a Smooth Slo-Mo Output
Use Apollo to Create a Smooth Slo-Mo Output.
The Apollo model is the perfect solution for creating smooth motion when slowing down a file by a factor of 4x or 8x.
For this example, we created an 8x slow-mo output.
Enable the Frame Interpolation filter and choose 8x for Slow Motion. We recommend using Apollo for this use case.
By default "replace duplicate frames" is enabled with a sensitivity of 10%.
Generate a preview and use the zoom tool to examine the results. If you are ready to export the file, select an codec and container add click the Export button.
Zoom to Fit
Zoom to 103%
Deinterlace and Upscale Noisy Footage
Convert 24/25 fps to 60 fps
