Upscale Low Quality to HD
You can use Topaz Video AI to upscale a low-quality file to HD.
For low-quality files, we recommend using Artemis Low Quality. If the results are not as expected, switch to Medium Quality or Proteus Fine Tune.
For this example, we will be using the Iris Low Quality model to reduce compression artifacts, reduce noise, and upscale to HD.
The input file (720x576p) is highly compressed and noisy, the Iris model effortlessly upscales the file to HD while reducing the compression artifacts and reducing noise.
To enhance and upscale your video using Iris Low Quality, select HD from the video out menu. This will lock the Enhancement filter to the 'on' state.
Next, choose iris for the AI Model and choose Low Quality for the input video condition.
Generate a preview and use the zoom tool to examine the results.
