Customize Preferences
Personalize your workflow by adjusting your preference.
Access Preferences
macOS: Click Topaz Gigapixel AI in the menu bar and choose Settings...
Windows: From the menus, choose Edit > Settings
There are two sections of preferences:
  • Settings
  • Shortcuts
The General section addresses in-app performance, preview, display, and custom settings.
The Shortcuts section shows hot keys or quick access to different features of the app using the keyboard.
Common Preferences to Change
Color Scheme
Change the application appearance between Dark or Light mode.
Go to Settings > General > Color scheme
System Color Scheme changes the application's mode based on your computer's setting.
Click Save to apply changes.
AI Processor
Gigapixel automatically attempts to choose the best option for performance.
Go to Settings > General > AI processor
You can select the dropdown menu to change your AI processor to the strongest or most powerful hardware available on your computer.
Unsure about which one to choose?
Reach out to our Support Team and share your System Profile for review.
Resize Type
By changing your Resize Type, your new settings will default in the Upscale section of the Filters Panel. These settings remain unless you manually change Resize Type again or default back to None.
Go to Settings > Upscale and resize > Resize type
Select the dropdown menu to select Set output size.
You can change between Scale, Width, or Height.
If selecting Width or Height, use the drop down menu to choose Inches or Centimeters.
