Command Line Interface
To use the Topaz Photo AI command line interface (CLI), follow the below instructions for your operating system.
Windows:
  1. Open Command Prompt or Terminal
  2. Type in:
    cd "C:\Program Files\Topaz Labs LLC\Topaz Photo AI"
  3. Type in:
    .\tpai.exe --help
  4. Type in:
    .\tpai.exe "folder/or/file/path/here"
Example Output
Processing Controls
The CLI will use your Autopilot settings to process images. Open Topaz Photo AI and go to the Preferences > Autopilot menu.
Instructions on using the Preferences > Autopilot menu are here.
Command Options
--output, -o: Output folder to save images to. If it doesn't exist the program will attempt to create it.
--overwrite: Allow overwriting of files. THIS IS DESTRUCTIVE.
--recursive, -r: If given a folder path, it will recurse into subdirectories instead of just grabbing top level files.
Note: If output folder is specified, the input folder's structure will be recreated within the output as necessary.
File Format Options:
--format, -f: Set the output format. Accepts jpg, jpeg, png, tif, tiff, dng, or preserve. Default: preserve
Note: Preserve will attempt to preserve the exact input extension, but RAW files will still be converted to DNG.Format Specific Options:
--quality, -q: JPEG quality for output. Must be between 0 and 100. Default: 95
--compression, -c: PNG compression amount. Must be between 0 and 10. Default: 2
--bit-depth, -d: TIFF bit depth. Must be either 8 or 16. Default: 16
--tiff-compression: -tc: TIFF compression format. Must be "none", "lzw", or "zip".
Note: lzw is not allowed on 16-bit output and will be converted to zip.
Debug Options:
--showSettings: Shows the Autopilot settings for images before they are processed
--skipProcessing: Skips processing the image (e.g., if you just want to know the settings)
--verbose, -v: Print more log entries to console.
Return values:
0 - Success
1 - Partial Success (e.g., some files failed)
-1 (255) - No valid files passed.
-2 (254) - Invalid log token. Open the app normally to login.
-3 (253) - An invalid argument was found.
Features
Plugins
