Other Applications
For any programs that are not part of our dedicated supported plugins - you can test if Photo can be launched if your application has an Edit with or Open with menu option (1). If the plugin works, you may need to re-import the processed image for it to appear within your application after Photo closes.
(1) Important: Incompatible plugins can have issues, conflicts and inconsistent behaviors. Any issues in these workflows are not supported when Photo used as a plugin. For any programs that are not in our dedicated plugins, we support using Topaz Photo as a standalone (from the Desktop shortcut), then export from the standalone, then use this exported file in the program of your choice. To use Topaz Photo as a plugin, make sure to use from one of our dedicated and supported plugins.
