Spot Healing
The Spot healing brush is now available in the enhancements menu. If you’ve used the Dust & scratch model, then you already recognize this tool as it was included as the second step to help remove larger damage that the AI model did not clean up. By turning it into a standalone tool, we are giving you a fast, lightweight way to clean up small sections of your image without needing to run the full Dust & Scratch workflow.
This tool is ideal for removing minor artifacts, blemishes, or imperfections with precision. Just use the brush to select a small area, and as soon as you release, processing begins instantly — no need to adjust settings or switch tools. It’s a quicker and more targeted alternative to the Remove tool, designed to keep your workflow smooth and responsive.
