Lightroom Classic
Adobe Lightroom Classic (LrC) is the desktop application of Adobe Lightroom.
Lightroom Creative Cloud (Lr) is currently not supported. Only Lightroom Classic (LrC) is supported as a plugin.
Topaz Gigapixel can be accessed through Photo > Edit in > Topaz Gigapixel (Studio). This will convert the file to TIFF, and send the image with the Lightroom Adjusments to Topaz Gigapixel. You can Edit a Copy without your Lightroom adjustments or Edit Original to overwrite your selected file.
Changing the file options is not recommended and can cause issues.
Sending RAW files to Topaz Gigapixel directly from LrC is not recommended as it will lock the RAW noise in the file and revoke the RAW capabilities because it will return a TIFF file
Cloud render is not available when using Topaz Gigapixel as a plugin
Batch Editing
The plugin function supports batch processing.
Select multiple images in the Library Grid or in the Filmstrip and:
- Right-click your images and click Edit In > Topaz Gigapixel (Studio)
Do not use Photo > Edit in > Topaz Photo from in the Develop tab. This only sends the currently viewed image to Topaz Photo.
