Topaz SCIM Attribute Reference
Overview
Use this reference when mapping attributes from your identity provider to Topaz SCIM.
Topaz Extension URN
Use this SCIM extension URN for Topaz-specific attributes:
urn:ietf:params:scim:schemas:extension:topaz:2.0:User
Standard SCIM Fields
Topaz supports these standard SCIM user fields:
userName
Recommended use: the user's email address or login identifier
active
Recommended use: user lifecycle state
Note: false is treated as a deprovision action
displayName
Recommended use: the user's display name
name.givenName
Recommended use: the user's first name
name.familyName
Recommended use: the user's last name
emails[].value
Required use: the user's primary email address
emails[].primary
Recommended use: identify the primary email value
externalId
Optional use: your identity provider's unique identifier for the user
Topaz Extension Fields
tenantKey
Type: string
Use: identifies the Topaz tenant
Example: tk_sample-tenant
Note: if sent, it must match the tenant associated with the bearer token
controllerKey
Type: string
Use: identifies the Topaz controller or team
Example: ck_photo-team
Note: required for provisioning writes
managedSeatEnabled
Type: boolean
Use: enables or disables managed-seat provisioning
Recommended value: true
managedSeatRole
Type: string
Allowed values: sub_user, sub_admin
Use: sets the Topaz managed-seat role
Recommended default: sub_user
managedSeatCount
Type: integer
Use: sets the managed-seat count
Recommended default: 1
productScope
Type: string
Allowed values: enterprise_default, selected_products
Use: aligns provisioning with the configured Topaz product scope
Recommended default: enterprise_default
ssoRuleAction
Type: string
Allowed values: bypass_sso, require_sso
Use: optional SSO rule behavior for the provisioned user
Azure Entra Mapping Guidance
For Azure Entra, treat these as app-level constants:
- tenantKey
- controllerKey
- productScope
In the simplest Azure Entra setup, these may also be constants:
- managedSeatEnabled
- managedSeatRole
- managedSeatCount
- ssoRuleAction
This gives you a working baseline, but it means those values are shared across users in that provisioning app.
If you need true per-user control from Azure, those fields must come from user-specific Azure attributes rather than constants.
For a standard enterprise managed-seat deployment, Topaz recommends:
- tenantKey: the tenantKey provided by Topaz
- controllerKey: the controllerKey provided by Topaz
- managedSeatEnabled: true
- managedSeatRole: sub_user
- managedSeatCount: 1
- productScope: enterprise_default
Provisioning and Deprovisioning
Topaz treats both of the following as deprovision actions:
- active=false
- DELETE /Users/{id}
This removes SCIM-managed assignments and marks the user inactive in tenant state.
Supported Search Filters
Topaz currently supports exact-match SCIM filters using eq for:
- userName
- emails.value
- externalId
- id
Examples:
userName eq "user@example.com"
emails.value eq "user@example.com"
externalId eq "entra-object-id"
id eq "123"
PATCH Support
Topaz supports SCIM PATCH with add, replace, and remove operations for supported fields.
Common PATCH paths include:
- active
- userName
- displayName
- externalId
- name.givenName
- name.familyName
- emails
- emails.value
- urn:ietf:params:scim:schemas:extension:topaz:2.0:User:tenantKey
- urn:ietf:params:scim:schemas:extension:topaz:2.0:User:controllerKey
- urn:ietf:params:scim:schemas:extension:topaz:2.0:User:managedSeatEnabled
- urn:ietf:params:scim:schemas:extension:topaz:2.0:User:managedSeatRole
- urn:ietf:params:scim:schemas:extension:topaz:2.0:User:managedSeatCount
- urn:ietf:params:scim:schemas:extension:topaz:2.0:User:productScope
- urn:ietf:params:scim:schemas:extension:topaz:2.0:User:ssoRuleAction
Azure Entra compatibility note:
Azure Entra may send Topaz extension fields as bare PATCH paths such as:
- tenantKey
- controllerKey
- managedSeatRole
- managedSeatCount
- productScope
- ssoRuleAction
Topaz SCIM accepts both the namespaced Topaz extension paths and those Azure-style bare paths.
Example PATCH Payload
"schemas": [
"urn:ietf:params:scim:api:messages:2.0:PatchOp"
"Operations": [
"op": "Replace",
"path": "urn:ietf:params:scim:schemas:extension:topaz:2.0:User:managedSeatCount",
"value": 2
"op": "Replace",
"path": "urn:ietf:params:scim:schemas:extension:topaz:2.0:User:managedSeatRole",
"value": "sub_admin"
Example Deprovision via PATCH
"schemas": [
"Operations": [
"op": "Replace",
"path": "active",
"value": false
Limits
Topaz does not currently support:
- SCIM Groups (coming soon)
- SCIM bulk operations
