Convert 24/25 fps to 60 fps
Use Topaz Video AI to convert 24 or 25 fps footage to 60 fps.
For converting 24/25 fps footage to 60 fps, we recommend using Chronos Fast. For this example, we will be using Chronos Fast to alter the frame rate on a 4K video file.
The input file (3840x2160) is an example of a fast-motion video at a low frame rate, the Chronos Fast model effortlessly smooths movement and converts the frame rate to 60fps.
To alter the frame rate of your video using Chronos Fast, select 60FPS from the video out menu. This will lock the Frame Interpolation filter.
Choose Chronos Fast for the AI Model. If your footage has duplicate frames, enable Replace Duplicate Frames.
Generate a preview and use the zoom tool to examine the results.
Using Apollo to Create a Smooth Slo-Mo Output
Stabilize and Remove Motion Blur
