Core Models
Our core AI models are considered non-generative AI models that allow for general enhancements across a variety of images and files. These AI models are available to process locally on your computer.
Standard
The Standard AI Model is the overall recommended model to use across a variety of images. This model has been trained to see a variety of files but works best for photos, graphics, and generated images.
Standard v2, first introduced in version v7.0.0, is the default version when Standard is applied.
Standard v2 reduces blurry patches that occurred in Standard v1.
High fidelity
The High Fidelity AI Model is trained to study high quality images with high resolution. Images from high end cameras are best. This filter can maintain the original look of images, without creating distortions.
This model intends to keep the original look of the image. It can be the most common upscaling filter after other denoise/sharpen filters.
Preserve the textures and authentic capture capture details with High Fidelity and minimally change details using the Denoise slider.
Standard v2 addresses more natural textures preserving them while maintaining sharpness.
Photo by Taryn Elliott
This particular model has a slower processing time in order to produce better output results.
To keep the look of grain or noise in the image, tune down the Denoise and Fix Compression sliders for more natural results.
Low resolution
Low resolution files are commonly identified as having fewer pixels. This model works best with screenshots, images pulled from the web or images with 72 pixels per inch (ppi).
Low resolution v1 (Legacy Model as of v.7.1.0) v1 is trained to remove more blur by default.
Photo by Esther Huynh
Text & shapes
Text & shapes enables more distinct patterns and shapes during upscaling with man-made objects, textures, and even written text and fonts.
This AI model is suitable for graphic design, typography, images with street signs, or text on architecture, automobiles, and more.
Photo by Marlon Soto
Photo courtesy of Fondo Antiguo de la Biblioteca de la Universidad de Sevilla
Art & CG
The Art/CG AI Model is best for artwork, drawings, illustrations, and computer generated graphics like Midjourney.
Midjourney Illustration created by legendary_fox_47504
