Enhance Resolution
This filter analyzes the image and intelligently generates new pixels to improve image quality. It cleans up imperfections due to minor noise and reduces blurry edges to increase detail.
When to Use
Enhance Resolution can be used without upscaling to:
  • reduce noise if Remove Noise removes fine details
  • increase details if Sharpen is over-sharpening your image.
  • make mild improvements to your image to increase quality further
Models
Enable/disable Enhance Resolution by clicking the toggle.
Enhance Resolution Toggle
The Enhance Resolution filter comes with different models for different situations.
Standard
For medium-quality images from point-and-shoot cameras and older smartphones
High Fidelity
For high-quality images from DSLRs and most modern smartphones
Graphics
For art and computer-generated images
Low Resolution
For low-quality images that have been highly compressed
Controls
These models can have up to three sliders to control the processing:
  • Suppress Noise: reduces noise in the image
  • Remove Blur: improves the details by correcting pixels on edges
  • Fix Compression: reduces distortion due to low starting quality
Enhance Resolution Controls
Recover Faces & Select Faces
Upscale & Crop
