Adjust Lighting
The Adjust Lighting filter changes exposure and contrast pixel by pixel to produce well-lit and vivid images.
It fixes the following issues:
  • underexposure
  • overexposure
  • low contrast
  • high contrast
Controls
Enable/disable Adjust Lighting by clicking the toggle.
Toggle
The filter will turn on and set the Adjustment to the default strength.
Adjust Lighting Controls
The Adjustment slider controls the amount of lighting correction applied across the image.
Positive values will try to create better lighting conditions. Dark images are brightened and bright images are darkened.
Negative values will intensify the original lighting conditions. Dark images are darker and bright images are brighter.
Preserve Text
Balance Color
