Balance Color
The Balance Color filter corrects color casts or incorrect white balance to produce natural colors in your image. This creates a better foundation for further edits and processing.
It fixes the following issues:
  • incorrect white balance
  • colorful lighting
Controls
Enable/disable Balance Color by clicking the toggle.
Toggle
The filter will turn on and try to create natural colors for the image.
Adjust Lighting Controls
The Temperature slider will further change the white balance to cool or warm.
The Opacity slider controls the strength of the correction and returns the original colors to the image.
Adjust Lighting
Remove Object
