Subject Mask & Refine
Autopilot will automatically analyze your image to mask the subject. This mask is used primarily to selectively sharpen the image.
Subject Selection
Hover over the "Subject" text in to view the current mask.
Click the Subject button under the preview or the Edit Subject button in the Sharpen filter to open the masking menu.
The masking menu includes AI models for automatic subject detection, mask feathering, and two brushes for manually changing the mask.
The subject detection comes with three models and a None option to turn off automatic detection.
- Default: identifies and selects an object in focus
- Portrait: identifies and selects people in focus
- Landscape: identifies land or water in focus and deselects sky
- None: no mask is created automatically
The feathering slider increases the mask softness at the edges. Less sharpening is applied at the edges. Comparison below is feathering at 0 (left) and 100 (right).
The overlay color and opacity will change the mask visibility. This does not affect the sharpening.
Brushes
Topaz Photo AI comes with two brushes of varying sizes. Swap between them with this toggle.
AI Brush
This brush creates and selects groups of pixels. Patch size can be increased with the menu below.
Basic Brush
A circular brush. Brush size can be increased with the menu below.
AI brush (left) vs basic brush (right).
Brush the image by selecting Add or Subtract. Click and drag on the image to brush. Right click to use the unselected option.
- if Add is selected, right click Subtracts
- if Subtract is selected, right click Adds
Clear Strokes removes all user changes to the mask.
Configure Autopilot For Subject Selection
Change the default subject type in the Autopilot settings. Navigate to the Preferences > Autopilot menu. Default Subject Type will let you pick the subject detection model used for every image.
